주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Change BGA CHIP Graphic? or replacement
Hi,
I have mac 20" 1145. And i have broken graphic card.
So i have a few question:
1. Is posible to desoldering CHIP BGA from Low Profile ATi Radeon HD 2400XT PCI-E 256MB DMS59 and soldering to imac? Or this is 2 differet bga chip?
2. Where I can buy good CHIP or Replacement ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
De-soldering chips to swap-out is not the best approach. BGA chips like this one require proper tools otherwise you'll just make a mess.
I would just find the correct graphics card to swap out if you think the card is not working.
But before you go there have you tried connection an external monitor to see if it works?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Why you unaccepted Dan's answer is beyond me, it is good sound advice. Perhaps he wasn't giving you the technical information you wanted. Many things are possible, that are not advisable. What you are wanting to do is beyond most techs' skill level, even if it were possible.
First Road Block: The 2 GPU's are based on different architecture. The ATI Radeon X600 XT (Native to your A1145) is based on the RV370 (110 nm process) Graphics Processor. The ATi Radeon HD 2400XT is based on the RV380 (130 nm Low-K process) GPU. NOTE: Graphic cards based off the Radeon X550 may interchange with your existing architecture., using the same RV370 chip. Some of what I have said can be confirmed here
2ND Road Block: Apple/Mac computers do not recognize a video card/chip unless it has the Apple firmware. Thus, even if you found a chip than physically can be attached to your card and still function, your A1145 will reject it without the chip being flashed with the proper firmware. If the chip is not properly flashed you will "brick" it. Wasting all your time putting the new chip on your video card. You are now back to square 1.
There is a site dedicated to people such as yourself that want and/or need to change the Graphic Processor in their Apple computer/laptop. Go here dig around. You might find what you are looking for without asking any questions. The site is very informative and the only place I know of to get custom Apple firmware for GPUs. It is very possible to find other video cards that will work in your computer that only need flashed to the Apple firmware to work in your A1145. If you don't find any mentioned there, ask about such.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
effektiveddd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 999
