주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon의 12.3메가픽셀 DX-포맷 F-마운트 DSLR 카메라.
interval shooting timer , not selectable in any menu
I used the IST, once before , when to used it again , but it is not an available option any more. it is gray and all the info that I can get is that it does not work with bracketing settings .. any ideas
thanks
FR
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
I had the same problem with interval not available. Took the 64G card out, 16G in. Interval available again.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
had the same issue.. didnt like my memory card.. I had used it week before.. then when I tried to turn on the camera it said the card was not formatted and I know there was data on it.. so now today I took the data off that card. put back in d5000 and it said it was not formatted .. I let it format it.. and now interval is off.. I threw in another SD card and its ok.. doesnt like this micro SD card now.. I have another one I have in there now.. but something is strange.. so try another SD card..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Got the same problem.
- Tried bracketing off
- Tried inserting the date and time again.
- Tried a full battery.
- Tried resetting the camera (hold i button + info button together for a couple of seconds).
- Tried all possible modes and settings.
Then I've read somewhere to somebody had issues due his 64gb card. Now I see Kevin above here say something similair. Back in the day the D5000 came out, 64gb cards were not that normal. So I might buy a cheap 8gb and see if that resolves the problem. If not, I'm out of options.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi. I removed the battery and inserted back in and ITS worked again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frank RUiz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 2,746
