주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
질문 마감됨
Copper shielding sticker (front camera - heat shield)
Hello
I have rather clumsily managed to break the copper grounding tape which is on both iphone 5S and C models.
This appears to cause a bit of ghost touching on the digitizer.
Has anyone any ideas about how to repair this, or where I might get a replacement part from?
Many thanks
John
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
ok great I will have a look and let you know. Some people say that the tape is for heat distribution and others say it is a grounding tape..
댓글 달기
답변 2개
I don't think the broken tape would cause that. I have a 5s on the bench right now with broken shield tape and no ghosting at all. Check to make sure your connector is properly seated or you may have a faulty replacement part.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I agree with Brian. I have repaired many a Iphone 5S frontcamera ect, flex that did not have the copper tape with no problems.
댓글 달기
I have found ghost touching can be caused by defective digitiser try a different display assembly it may just do the trick.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,349
