주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 6월에 출시된 Apple의 6세대 무선 베이스 스테이션입니다. 이 타워형 기기는 듀얼 밴드 지원 무선 액세스를 제공하며 802.11ac 기술을 탑재한 Apple의 첫 번째 라우터입니다.
Thermal pad replacement comments?
I took my AirPort Extreme apart to give it a clean because it was full of dust. I thought I would remove the heat sinks just for interests sake. When I removed the heat sink I noticed it had a thermal pad between the sink and the Broadcom router chip. I was a little disappointed this was not mentioned in any of the tear downs as I like to replace thermal pads when I pull things apart. I had to put it back together as was but I am looking to replace the thermal pad. Does anyone have any suggestions? Also any suggestions on pad thickness? I was thinking 3mm from memory. IT seemed like a fairly big gap from memory. Any comments greatly appreciated. Also from memory there was definitely only one thermal pad yes?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
These might work for you:
https://www.ebay.com/i/302812527840?chn=...
maybe these
https://www.amazon.com/Fujipoly-Extreme-...
or maybe one of these:
https://www.amazon.com/s/?ie=UTF8&keywor...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
opinio 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 534
