주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Iconia Tab B1 제품군의 첫 번째 태블릿인 Acer Iconia Tab B1-A71은 2013년 1월에 발표되었습니다.
How to replace charging port?
Im attempting a charging port replacement on the tablet, i've got the old charging port off without any issues however I can't get the mounting holes free from solder to fit the new charging port in.
Could anyone advise on what I could try, tried solder wick but doesn't help much as I can't get enough heat into the solder between the holes
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
Position the new port with its feet in place, then heat the area (I used a heat gun carefully) while applying a little bit of pressure with a pair of tweezers.
The solder (or whatever it is) will soften with the heat and the port will sink in. Remember to remove the yellow tape from the topside first!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
EvansITLtd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 2,336
