주요 콘텐츠로 건너뛰기
Microsoft Band는 기기의 한쪽 면에는 직사각형 LCD 스크린이 있고 다른 면에는 심박수 측정기가 있는 손목 도구 및 액세서리입니다. 다양한 종류의 스마트폰과 연결할 수 있습니다. 모델 번호는 1619 이며 밴드를 고정하는 2개의 고리 옆에 작게 인쇄되었거나 원래 포장의 아랫면에 적혀있습니다.
How water resistant is the Microsoft band?
I accidentally dropped the Microsoft Band into water. It seems to be working, but should I still be worried?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The Microsoft Band isn't completely waterproof. Though it meets the IPX7 standard in testing, the Microsoft Band is not intended to be immersed in water and immersion is not covered by the warranty. Light rain or hand washing shouldn't harm it, but immersing it in water can damage and impair the screen, microphone, and batteries. Try not to wear it when you're swimming, washing dishes, or taking a shower. You can replace the damaged parts by following the guides for the Battery Replacement, the LCD Screen Replacement, or the Sensor Ribbon Replacement.
Additionally, if the Microsoft Band is dropped or receives an impact, its water resistance may be impaired or weakened. Take care to avoid sudden shocks.
Microsoft Band LCD Screen 이미지
안내서
Microsoft Band LCD Screen Replacement
난이도:
조정
10 - 15 minutes
Microsoft Band Sensor Ribbon 이미지
안내서
Microsoft Band Sensor Ribbon Replacement
난이도:
조정
15 - 30 minutes
Microsoft Band Battery 이미지
안내서
Microsoft Band Battery Replacement
난이도:
쉬움
10 - 15 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Do you know where I can buy finishing parts to microsoft band? It is the part that protects the battery (which has screws). It is whole peeled from my use. It is easy to exchange but I don't know where can I buy these two parts.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hello Fernando,
Unfortunately, at this point we can't buy any specific parts of the Microsoft Band. This is because the Microsoft Band was just released recently and its manufacturing process doesn't allow us to access its individual parts. Eventually, however, you will be able to find the components of the Microsoft band online.
댓글 달기
답변을 추가하세요
Monique Salinger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,964
