주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2003년에 출시된 IBM의 견고한 노트북으로, ThinkPad 브랜드는 현재 Lenovo가 소유하고 있습니다.
How to reset supervisor password
OK mother in law loaned out her old IBM r40 when it came back it had a password on it when asked the the person said humm I don't rember. Well now it ends up in my hands. I tried the clock battery removal no luck. It shows a it shows the IBM splash screen then goes to a lock with the number 1 next to it and I think that means its a supervisor password. Could just be a HDD not sure. But I do know thinks to the security chip I'm locked out. Any help would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
선택된 해법
Here is an IBM backdoor Bios password "merlin" all lower case no quotes...Let me know if it works...
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
If not I'll look for a boot cd that you can download and remove the password with...
의 공유
Here is something else you can try....
THE MOST EASIEST WAY TO BYPASS THE BIOS USER PASSWORD (not to enter the Bios but to enter computer Windows).
1.When you turn on the computer you wait until it say: “Enter Password”.
2.When the first step is done you press and hold End for about 3 seconds.
3.While holding end press Enter and you will be on your way to Windows.
의 공유
Now if your not getting a prompt to enter a password, your hard drive could be bad. You then will have to connect it as an external drive to another computer and see if it is recognized, If it is recognized see if you can access files. If you can access files, then run a check disk..If it all checks out good, then it may not be booting up if the MBR (master boot record) is corrupted, then you will need to fix the MBR with a program.
의 공유
댓글 달기
답변을 추가하세요
edwarddugger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 10,173
