주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Super Nintendo Entertainment System(SNES) 또는 줄여서 Super Nintendo는 1990년에 Nintendo에서 출시한 16비트 게임기입니다. Super Nintendo는 당대 최고의 베스트셀러 중 하나였으며 오늘날에도 여전히 많은 팬층을 보유하고 있습니다.
Every button pauses the game!
Ive tried several controllers on my super nintendo and every game all the buttons pause the game. up, down, left, right, a, b, everything pauses the game. it is the console, how do i fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
I have the same exact problem. It can't be that uncommon but I have not found an answer.
의
Hi, I'm having g the same issue, it's 100% not the controller ports as I've swapped them out with a mates and same issue persists. player 2 is unaffected.
I'm going to look at the motherboard later last I'm running out of ideas, hoping it's something simple like dirty trace or capacitor gone.
의
댓글 달기
답변 3개
Your controller port is busted. Check the pins they may be corroded. Try to clean the pins first with rubbing alcohol or compressed air. If that does not work you will need to replace the controller ports and pins.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I tried swapping the controller port as well and it didn’t work. Did anyone find a fix for this yet?
의
댓글 달기
That's usually caused by the flat cable that goes from the controller board to the motherboard. All you have to do is either replace it or remove it and solder wires for each trace instead. Some good old cleaning with some IPA will sometimes be enough tho.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What you should do is Open it up. Clean the contacts with some isopropyl alcohol. And it should work !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SimonFett 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 3,500
