주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
Battery not charging after minor water damage
Hello,
My wife spilled the smallest amount of tea on her a1425 Macbook Pro Retina from late 2012. After letting it dry she tried to see if the laptop was still working. At first it looked promising because the system started up normally and everything was running without any noticeable difference until she tried to run in from the battery.
As soon as the MagSafe was disconnected the unit shut off immediately. After plugging back in she noticed that the battery status says replace now and that the battery is not charging. The LED on the MagSafe starts out green and then turns amber and stays amber while connected.
We tried to thoroughly clean the internals with isopropanol multiple times but it made no difference. I also tried replacing the DC input board, tried a different (new) MagSafe adapter, and tried a new logic board (820-3642).
Nothing seemed to make any difference. I would hate to have to replace the batteries because they only have a cycle count of ~220, but is it possible that the batteries are the cause of the problem or is there a fuse or resistor that could be the culprit? If you have any any additional questions please let me know.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Steve, "replacing the DC input board, tried a different (new) MagSafe adapter, and tried a new logic board (820-3642)." the only thing left is the battery
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Steve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 723
