주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
Screw size guide or chart?
Does anyone have any information on the screw sizes on the iPhone 6. Particularly the 5 screws that hold the lcd,digitzer, home button and speaker flex metal bracket/plate down. Going back to the iPhone 5 I remember that using the wrong screw size can lead to damaging the motherboard. Sometimes the screws can get muddled up for whatever reason so I'd like to be sure I always use the correct screws when replacing screens etc. Any help on this would be very appreciated. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 18
댓글 달기
답변 4개
선택된 해법
craigad24, just use the guides like this one. Each step will have the screw size listed in it.
이 답변이 도움이 되었나요?
점수 12
댓글 6개:
Who can tell the difference in 1.2 and 1.7 mm? PLEASE SOMEONE WITH PICTURES THAT WE CAN PRINT OUT! And while you are at it make a printable map for each. One of you has it done already. Even if they weren't life size pictures of the screws comparing them would help! I don't care if you tech dudes think I'm an idiot, I am when it comes to this. (at least I can skateboard!)
I don't think anybody on here thinks you are an idiot. You are right, a difference of a mere 0.5 mm is hard to spot by eye. I would use an inexpensive set of calipers for that. Sometimes you can spot the difference by comparing the screws side by side.
my husband has a caliper that i used to measure the screws....you just have to find a site that has the right screw size
Eyeball both of the screw's and take a guess which you think is the longer one. Then verify your visual by getting a small cheap level from the dollar store. Stand both screws up. Put the level on top of the screw's. That should tell you which is the taller of the two. Flip the level left to right and up and down to make sure. Just an inexpensive idea that should/might work for $1.
댓글 1개 더보기
댓글 달기
I measured these using a digital caliber. This is off of an iPhone 6, 4.7screen. I measured the entire screw length. The measurement is for the entire screw length
이 답변이 도움이 되었나요?
점수 10
댓글 6개:
Thanks! Putting them side by side with a magnifying glass I could guess 1.32 v 1.34.
could you guide me on actually how to use the digital calipers on screws , i gave up and bought the caliper just for this project
A good video would be https://www.youtube.com/watch?v=oJy8S6r2.... Be sure to turn on the caliper closed, that way it calibrates properly.
The screw was measured by placing in the caliper as shown in picture.[image|1139208]
Hi MSFA ! Do you have iphone 6s back camera grounding flex cable two screws size. And which end of the that cable go to which point. The one goes to the camera the other goes to the point next to the camera cable port. And could you measure for me those two screws size.
댓글 1개 더보기
댓글 달기
i am using a magnetic screw chart mat like this one, works perfect
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
What If you let fall down and all the screws spread in your so softly screw color carpet ? ?????
I keep a strong magnet near my work. One screw will always attempt escape.
댓글 달기
Do you measure the whole length or just to the head
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
The whole screw, head and thread
댓글 달기
답변을 추가하세요
craigad24 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 130
전체 시간: 134,954
