주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S5 Active SM- G870A는 2014년 6월에 출시되었습니다. 이 기기의 수리는 광범위하며 휴대폰 도구 키트 및 열선총이 필요합니다.
USB Charging Port Cover/Flap replacement?
Just checking how to replace the S5 Active's USB port flap. The regular S5 looks pretty easy but the S5 Active doesn't have a screw close to the flap.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
Thank you! I've had the cover/flap on by Gorillia tape since i posted up here and hs worked pretty well. The S5 Active covers are ridiculously expensive compared to the regular S5 so I haven't taken it on yet but might soon.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
ATT provides free replacement, I know that much
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Did they send back to Samsung to fix or there in store? Plus locally the closest AT&T service center is an hour away.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check out this thread Repair/Replace USB Charging Port
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Don't know about the Active. I have an S5 Sport. My port cover flap broke right in the middle. The extension that forms the hinge / retainer stud is a tough but flexible material. It stretches. I grabbed it as close to the little opening as I could with a pair of needle-nose pliers, pulled it slowly, it stretched, I choked up, pulled some more, it stretched, I choked up, pulled some more and it popped right out. I had purchased a replacement cover online, about $10. I was able to press that into the hole using a pair of precision screwdrivers. The whole thing took about 5 minutes. I was afraid the little piece that forms the retaining stud would break off inside the phone. That did not happen to me. If it happens to you, you won't be any worse off than you were before.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
MattCFII 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 34
전체 시간: 5,112
