주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 S7562로 식별되는 Galaxy S Duos는 Samsung이 제작한 dual SIM 카드 스마트폰입니다.
My touch screen is not working
my samsung galaxy s duos touch not working what shall i do ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
did it stop responding after a drop or were you just using it and it stopped?
댓글 달기
답변 1개
선택된 해법
I would do the following before considering a screen replacement.
  • Restart the phone
  • Inspect the cable, the cable should be accessible without unscrewing the back. Remove the back case and on the upper left corner you will see a plastic piece with a little slit that you can pry open. Remove the battery, pop that chamber open, and disconnect the cable and look for signs of damage or corrosion. If you clean the cable or no signs of damage are evident then you may need to replace the LCD/Digitizer.
If the issue happened after the unit was dropped then more or less it may have suffered damage and the digitizer is affected.
Good Luck
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
awabdehw 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 1,961
