주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Iconia One 7은 2014년 4월에 출시된 태블릿입니다. Iconia One 7은 미디어 콘텐츠를 즐기기에 최적화된 소형 기기입니다. 패블릿보다 큰 디스플레이는 선명하고 다채로운 화면을 제공하며, 빠른 반응 속도와 긴 배터리 사용 시간을 갖추고 있어 언제 어디서나 편리하게 사용할 수 있습니다. 또한, 부모가 직접 관리할 수 있는 다양한 어린이용 콘텐츠가 포함된 Kids Center 플랫폼이 함께 제공됩니다.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
의
Nop. Problem still remains.
의
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
의
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
의
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
의
댓글 달기
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I wanna ask on what button should I select to organize my apps?? Thank you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ricartengenheiro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 2,480
