주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2007년형 모델부터 Escalade는 새로운 GMT900 플랫폼으로 변경되었습니다.
replace the lamp above my right headlight
Step by step instructions on how to replace the small lamp above the headlight on the right side of my Escalade. I am a a single female doing it for the first time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Sounds like someone else has had this same question on this forum. In my experience, though, you should be able to unscrew the dust cap from the back of the headlight housing where the connector is to replace just the bulb. I, unfortunately, do not have an Escalade in front of me to see if this is also the case. From looking around at a few different places, it seems it might take some more work.
Something else you might try is going to your local Autozone, show them the bulb that needs to be replaced, and have them take a look at it to see if it's a simple install.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Pat Kerbs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 3,613
