주요 콘텐츠로 건너뛰기
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20 질문 전체 보기
black screen and 4 beeps
No picture want start, black screen and 4 beeps
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
Kissah Davis, 4 beeps on your Dell are for a Memory read / write failure. This could be caused by a bad memory module. First you should try to reseat it. To do that you fully open the securing clips, align the notch on the bottom of the module with the crossbar in the connector, place several fingers on top of the module and firmly push the module down into the slot, until the module snaps into position. If the module is inserted correctly, the securing clips will snap into the cutouts at each end of the module.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
After I'v done the laptop still has black screen BUT no beeps
댓글 달기
check screen.....press d and power button
이 답변이 도움이 되었나요?
점수 0
댓글 달기
that sounds like a power supply unit problem get a can of blow-out and blow it out real good.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kissah Davis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 7,957
