black screen and 4 beeps
No picture want start, black screen and 4 beeps
좋은 질문입니까?
Kissah Davis, 4 beeps on your Dell are for a Memory read / write failure. This could be caused by a bad memory module. First you should try to reseat it. To do that you fully open the securing clips, align the notch on the bottom of the module with the crossbar in the connector, place several fingers on top of the module and firmly push the module down into the slot, until the module snaps into position. If the module is inserted correctly, the securing clips will snap into the cutouts at each end of the module.
이 답변이 도움이 되었나요?
After I'v done the laptop still has black screen BUT no beeps
that sounds like a power supply unit problem get a can of blow-out and blow it out real good.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 8,287
