주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
더 부피가 큰 ThinkPad T420의 슬림 버전입니다. T420s는 기존 T420 노트북보다 배터리 사용 시간이 짧고 팬 소음이 더 큰 것으로 알려져 있습니다.
How can I install more RAM?
My laptop is running a little sluggishly, and I want to upgrade the amount of memory. How would I go about doing this?
Update (04/26/2015)
If you would like to install more RAM, please note that 1333 MHz SO DIMM is the recommended memory for this system. There is an excellent installment guide here.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
You may want to make sure the reason of your system sluggishness is not caused by malware. I will run first CCleaners & Malwarebytes Anti-Malwares first (you can download those for free in Cnet.com).
Then if it looks good, you can go on www.crucial.com which will scan your system and tell you the proper upgrade for your system, so you don't buy or install the wrong one as it will destroy your system.
Make sure you follow proper installation which you can find on ProfessorMesser.com
Good luck!!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You may need the most recent BIOS update but the T420s supports 16GB of RAM, not 8 as previously (and correctly at the time) published. You can use RAM that is faster than 1333 MHz, but it will not use a faster speed than 1333 MHz.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tristan Broughton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 963
