주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
574 질문 전체 보기
blue spots on my screen
i dropped my macbook a1278 and the screen has blue spots . i am told that i need to change the graphic card. can graphic card be changed or the whole mother board needs to be changed?
let me know which parts needs to be changed and cost of the part and the step by step how to replace it .
Update
Update
HI DAN
i posted 4 pictures and the last picture shows the full serial number .
so serial number is : W8849MLY1AQ
regards
Roger
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개:
Can you post a couple of good pictures so we can see. Often when one bangs there system they damage the LCD display panel.
Also please include the last four figures of your serial number so we know your exact machine. Some machine models have known issues.
Thanks Mayer! I got over focused on the blue spots ;-}
댓글 달기
답변 1개
Do you have access to an external display that you can plug in? See if the image is clear on the external. If so we know the problem is strictly within the internal display circuitry at that point.
Here is the IFIXIT guide to open up your system to replace the display assembly which is the easiest way to fix this: MacBook Unibody Model A1278 Display Assembly Replacement. But before you do that lets first try reseating the displays data cable. After opening the system as outlines in the first few steps (to Step 5) jump to Step 9. After removing it make sure there is no dust in the connector and reseat it. Power up the system to see if that fixed it. If not its time for a new display.
Replacing the complete assembly is more expensive it is the easier path. Your other option here is to replace only the LCD panel but its a lot more work and you do need to be careful as you can damage/break parts in the process which will either make your system look trashy or cost more in added parts. Here's the IFIXIT guide for the LCD replacement: MacBook Unibody Model A1278 LCD Panel Replacement
MacBook Unibody Model A1278 Display Assembly 이미지
안내서
난이도:
운영
MacBook Unibody Model A1278 LCD Panel 이미지
안내서
난이도:
매우 어려움
2 - 4 hours
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
hoe2003 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 256
