주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1세대 Ford Focus는 1998년부터 2004년까지 유럽에서, 1999년부터 2007년까지 북미에서 생산되었습니다.
brake warning light stays on
my brake warning light stays on cleaned terminals
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Thanks for the info! I pulled er brake up to clean the “boot” the day before I found the dashboard brake light on and hoped that was the problem...so I pulled it up and released it 3/4 times. And today the light was off! Will check in w/mechanic anyway...
의
댓글 달기
답변 2개
have you checked your parking brake?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check that your brake fluid reservoir is full of fluid! My clutch was leaking and while the reservoir is designed to not allow the clutch to draw below the line necessary for the proper operation of the brake, the brake light was still on intermittently. It is a float sensor that checks the fluid, make sure it is not stuck. WillieP is also right in checking the sensor for the parking brake, it is simple wire that when grounded will turn the light on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kevin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 3,838
