주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Zenbook UX31A는 2012년 6월에 출시된 노트북입니다. Asus의 울트라북 라인업 제품으로, 3세대 Intel Core I7 프로세서와 풀 HD IPS 디스플레이를 탑재하고 있습니다.
How to fix power button?
My problem is that I can't turn my Asus on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
It is most probably this problem :
반응하지 않는 키보드 수리
See also :
Asus Zenbook UX31A 반응하지 않는 키보드 수리
Asus Zenbook UX31A 이미지
안내서
반응하지 않는 키보드 수리
난이도:
쉬움
10 minutes
안내서
난이도:
쉬움
15 minutes
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you may have slipped any liquid on the keyboard, it may become not responsive. As the only option to power up the laptop is via pressing the 'power' button on the internal keyboard, you won't be able to turn on the laptop.
Removing and cleaning the keyboard may help but not necessarily -- this laptop's keyboard is a thin thing and you can't really clean 'in-between' its layers.
You may want to replace the keyboard as the first option.
Or if you reasonably suspect that the liquid could have gotten further down from the keyboard unit, you may want to 'ring-out' your motherboard first.
As to me, I've firstly checked that the motherboard was OK, then replaced the keyboard. Everything started to work as a chime.
If your keyboard works but the touchpad doesn't - check that the touchpad wire is firmly connected (from memory, to the back of the keyboard rather than to the motherboard -- but I can't remember for sure). Sometimes the connection gets lose (and may especially get lose while you are working on replacing the keyboard).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dai Quy Phan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 10,642
