주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
수년간 많은 훌륭한 앨범을 녹음하는 데 사용된 완전 기능형 전문가용 DAT 기기입니다.
How do I rescue a DAT?
I have a DAT tape that is stuck in a Panasonic SV–3800 machine. At first, just wouldn't play audio, on this machine or on an SV-3700, but it did at least fast wind. Now the machine won't eject or play or do anything. I have tried powering it up several times. The literature I have seen online is insufficient, so far. I have had experience with ADATs in the past, where you could manually move a wheel inside to guide the tape out, but the wheels I see inside this machine won't budge. It is hard to tell if the tape is damaged, since you can't see it from the outside of the machine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hello, you will need to remove the cover and locate the loading wheel which is on the right rear of the loading carriage, it has the rubber band on it that connects to the loading motor. Start pushing the wheel away from you til the carriage is completely open, from there you can remove the tape if it is not loaded inside up to the drum, if it is you will need to remove the four screws that hold the upper carriage to the base and manually pull the upper carriage off and remove the tape.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
OK, I have an SV3900 Panasonic DAT and While I can take the screws off the side and back, the front top will not release. Now what?
의
댓글 달기
답변을 추가하세요
Rich Lamb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 1,595
