주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 드론은 Wi-Fi를 지원하며 내장형 HD 카메라가 탑재되어 있습니다. 사진 촬영 및 영상 녹화용으로 사용됩니다. 모델 번호: PF722000
Bebop drone - Camera front glass
Hello.
I have scrached the grass of the camera (bebop drone). Is there a way to change the glass? This product (EPP nose) doesn't contain glass? I mean... the glass in front of the bebop is the camera glass without any protection?
Thanks a lot
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 5개
가장 유용한 답변
You can try this:
http://chtech.co.za/wordpress/parrot-beb...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Please can you contact me at harrisonashley8357@gmail.com thankyou regarding your diy lens
의
댓글 달기
Check out this: https://www.youtube.com/watch?v=uyO5qx81...
I haven't tried it yet, but need too. I scratched the lens of my Bebop as well, but don't need to replace the entire camera. I hope iFixit can source the replacement lens for us: that would make life a LOT easier!!!!
- Jeff
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The result is in focus but one can clearly see the effect of the lack of anti-glare coating.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My front broke can it be replaced
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If it’s out of focus than it’s easy fix; all you’ll need to do is to watch YouTube video.
but sometimes the camera itself is broken & if you attempt to turn on your Bebop that all it gives you is Blinking green light & nothing else.
to fix this problem all you’ll need to do is to watch another YouTube video while you remove the front Nose, remove the Camera housing, than disconnect it from the MotherBoard; Screw it back together & you’ll have a working Drone without the FVP(Camera view) but you can still fly it whiteout any problems.
All Thanks to parrot.com to have &&^&@@ us all; They manufacture Bebop Camera Replacement but for $300+ that they can go stick their heads up their ass, as I’m sure by now it’s the exact fit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
cinepallas2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 9,842
