주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T400s was a laptop introduced by IBM for corporate and commercial use. The T400s was released along with the T500 in July of 2008. Similar models include the 400, 410, 420, 510, and other models in the ThinkPad T series.
5 질문 전체 보기
질문 마감됨
Can I use a different watt power adapter?
I lost the 90W 20V power adapter that came with my T400s laptop. Could I use a power adapter from a T430S interchangeably? It is a 65W 20V power adapter.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Esther Chen, it will take a bit longer to charge your battery etc, but you should not have any big issues with that. Only thing you want to check is that it does not get to hot in case your T400 pulls to many amps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
sometimes, your power adapter wont work loner
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes, both power adapters should work fine for the Thinkpad. However, there may be limitations for the 65W power adapter: the battery will take longer to recharge and it might not be powerful enough for certain types of usage (ex. watching a DVD while at the same time running HDD intensive applications).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 155
