주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Logic board damage - what is this component?
Hi.
I've recently discovered my MacBook's logic board was damaged, probably by the previous owner.
Picture 1 - Before cleaning
By the look of it, I guess it was Coke. After cleaning it with isopropyl alcohol, it looks like this.
Picture 2 - After cleaning
As you can see, two pins of the component in the red circle are destroyed, but the device is working properly and I haven't noticed any strange behaviour.
So my questions are:
What is this component?
Which circuit is it part of?
My plan is to buy a cheap broken logic board from eBay and replace the component. My technician friend told me that was a good idea, but that I also could use it like this, because it's probably ("probably" - this is what worries me) a component which is not that important.
Thank you in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
That is U 5410 which is a TI INA214 in a SC70 package which is part of your computer sensors. This one monitors the high side current and "reports" it to the SMC. If you run a AHT it should give you a sensor error. Replace it to avoid any sensor related issues
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks!
Just to be sure, can this one do the job?
http://www.ebay.com/itm/IC-CURR-SHUNT-MO...
Some of the values are different so not sure how this will interfere with the function for the sensory circuit. I'd stick closer to he original values http://www.ti.com/product/ina214
댓글 달기
귀하의 답변을 추가하세요
vektor42 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 84
