주요 콘텐츠로 건너뛰기
The Nikon D7000 is a 16.2 megapixel DSLR launched in 2010.
Why won’t my camera turn on?
I tried turning on my camera but nothing is being displayed.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
i had the same issue but got it repaired at mata electronics in bangalore.thanks to them contact them at mataelectronics@Gmail.com
댓글 달기
답변 5개
선택된 해법
here are a number of issues that can cause the camera not to turn on. Look at the troubleshooting page for more details.
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
my camera will not on even you put the battery and put it on
do i need to chance the battery?
I already full charged but still couldn't on
try new card in camera , also make sure battery is in properly the right way round.
댓글 달기
가장 유용한 답변
Hi,
Is there a display on the top panel or is that blank as well?
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Hi, I have one that won't turn on and the Tip panel is blank. Normally when it's off with a battery there's normally some icon showing but now there's nothing.
I have the same problem too
Nothing, I did try a new battery but nothing either
댓글 달기
check that battery is fully charged.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Usually it is the DC/DC board that has some part broken
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Ciao Antonello, io ho una D7200 che non si accende minimamente e non visualizza nulla ne sull'LCD principale ne su quello secondario in alto. Aprendola, ho visto che la DC arriva correttamente alla scheda madre. Come faccio a verificare se è la scheda DC/DC o è proprio la scheda madre ad avere problemi?
Ciao non conosco la D7200 ma di solito tutte le Nikon si accendono anche senza la motherboard
댓글 달기
Replaced batteries and took XQD card out with no results; had SD card in.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jed Chen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 39
전체 시간: 41,242
