Device will not display
After putting disc in SuperDrive no device display appears on computer screen and so cannot eject disc.
How can I eject disc either by getting drive to display or open drive and manually eject?
좋은 질문입니까?
좋은 질문입니까?
Hooked up to MacBook Air
이 답변이 도움이 되었나요?
Is the drive meant to show up like usb do?
Go under Finder, to the left of the Apple in the upper left hand corner to Preferences. Click on general > CDs DVDs, and iPods. See if the icons shows up on the desktop. Drag it to the trash, or click once on it and go under File > eject. this failing restart and hold down the trackpad button.
I thought my SuperDrive had broken, as my MacBook Air no longer found it when it was connected, not in finder despite audio disc inside it, and the drive not making any noise at all. So I bought a new SuperDrive. Same problem, so I phoned Apple support and six different people have failed to fix it. Looking on google I saw one solution, restart the macBook with the SuperDrive already connected - success! I copied the CD and ejected it. However that is the ONLY way I can get it to work - it has to be connected at startup, and wont be recognised after that if disconnected and reconnected again. The old drive is the same. Any fix appreciated, thanks
I also think mine is broken cannot get through in any way? any suggestions what to do?
Apple found and fixed the problem - there was an extension on my Mac called RIMBBUSB.kext which was the cause, and deleting that fixed it. Apparently it is part of Blackberry software, which makes no sense in my case as I don't have a Blackberry. I did use a friend's dongle before this problem and wonder if the software was downloaded by that.
Have owned Apple laptop computers for 15 years, and absolutely loved my first two computers. This third computer, a MacBook Air, purchased in the summer of 2020, has been nothing but trouble. My USB Superdrive failed to eject twice. Apple team’s solution was to order me a new Superdrive. Now the new Superdrive which I’ve had for less than two months is failing again. Same problem again! None of the online suggestions help me. The same problem, but always with a different disk too!
Also worth mentioning that I had a hassle trying to order my computer in the summer. Placed my order three times. Had to contact Apple’s president myself to place the order.
Won’t ever buy another Mac.
이 답변이 도움이 되었나요?
지난 24시간: 4
지난 7일: 10
지난 30일: 30
전체 시간: 18,245
댓글 4개
What do you have it hooked up to?
mayer 의 공유
2020 iMac 27"
democratic hope 의 공유
2020 iMac 27" screen @mayer
@democratic hope - Go under Finder, to the left of the Apple in the upper left hand corner to Preferences. Click on general > CDs DVDs, and iPods. See if the icons shows up on the desktop. Drag it to the trash, or click once on it and go under File > eject. this failing restart and hold down the mouse button.
mayer 의 공유
