주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 11월에 출시된 2세대 스마트폰입니다. 스텔스 블랙 또는 폴라 화이트 색상으로 제공되며, 32GB 또는 64GB 저장 용량, 마이크로 유심 카드 슬롯을 지원하고 SD 카드 슬롯은 없습니다. 모델 번호는 PM63100입니다.
Accidental screen damage due to fire
Hey. Recently, I had a kitchen accident involving my phone. I switched on a baking oven without realizing that my phone was inside. I adjusted the burner to 350 degrees Fahrenheit. About 15 seconds later, I realized that my phone was inside!! I shut off the burner and retrieved the phone. The right half of the screen was completely black and the phone was very hot. Slowly however, the blackness started to go away and the phone cooled down. Luckily, it operates normally except for two things: the pictures from the front camera are a bit hazy; and, there is some fading on the right side of the screen.
Now, to my question. What can I do to fix the screen? Should I replace it? If I don't, could the fading spread or become more intense?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
In order to replace your screen use this guide, however given your description of the "hazy camera" you may have some issues other then the screen fading, in that case go seek professional help from a local repair shop in your area.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Farooq 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 318
