using current size in printing and copy
how can i solve my printer canon mf 4350d is coming error for printing and copy, useig current size is coming
좋은 질문입니까?
좋은 질문입니까?
Hi,
I had the same issue, try this, it worked for me, and prints two pages straight.
I'm using a Mac,
COMPUTER SETTINGS
Set the document you want to print
In the printer settings, change it to 'US Letter'
PRINTER SETTINGS
Go to 'paper settings' click OK on 'Cassette' and then press the + button and select 'Ltr' for the paper size. It then displays the words 'plain paper' press OK, and you should be good to print.
Hope it works for you.
이 답변이 도움이 되었나요?
This method works great! Many thanks! After using canon d480 print for 7 years and wasted many many copy papers, I finally found the simply solution. For me, the problems only occur when copying, printing from computer was no problem from the beginning.
Edward
The problem still persists. :)
no, this doesn't help
I love my MF4350d and has served me well for over a decade. Last year I moved and had my printer in storage for over a year. After acclimating to my new home, it now prints or copies the page and a blank page. It sounds like it is trying to grab a sheet about 4 times. Finally ends in ERROR with ""USE CURRENT SIZE Y/N" I've tried cycling through Paper Settings (Cass/LTR/PLAIN), removing paper & adjusting the guides, Collate settings. Nothing helps.
Don't know what else to try.
Hello,
I had the same problem with my canon i-sensys MF 4350d
I just changed the paper type from letter to A4 from my printer settings of the document that I want to print
이 답변이 도움이 되었나요?
It doesn't seem to matter which paper type I have. I have had this problem for several years now and have been dealing with it. I will not deal with it anymore and am ready to go buy a new printer, just not a Canon. I need to print multiple pages and really don't have the time to try and figure out what is wrong. I can only print 1 page before it gives me an error and states " Use current size".
Don't confuse paper type with paper size, this mean two different things to a Canon (or most any) printer. Your driver settings must match both paper size and paper type as configured at the mschine. Plain1 is different than Plain 2, for example. Look at your error messages carefully abd adjust either the paper type in the printer menus, or adjust your print driver settings. Always make sure the cassette guides are cinched up and no paper is trapped behind the cassette (aka paper tray).
Go to Printing Preferences and change both the Paper size and Output size to Letter or the size of paper you want to use. DO NOT select Match Paper Size for Output size.
이 답변이 도움이 되었나요?
This is not the issue that any of us are having. We already have the paper size and output size the same and correct. This issue just starts randomly, and then it never stops. You normally get one page and then a blank page, then an error. Once in a while, I have obtained more than one page, then a blank page, and then and error.
@nickcroglio Make sure the size is shown correctly on the screen (e.g. copy mode) otherwise your tray guides might be out of the correct position. Other possibilities are paper trapped behind the cassette, or a defective cassette size detection microswitch assembly.
By the way, if your print driver is set to print on Plain 1 paper type, but in the machine paper type settings the tray is set to Plain 2, it will create an error messsge. The paper types must match EXACTLY between the print driver abd machine. Again threr things; paper size, paper orientation, paper type (sometimes known as paper weight).
This actually helped my output was on A4 and not letter. It works now.
By the way, if your print driver is set to print on Plain 1 paper type, but in the machine paper type settings the tray is set to Plain 2, it will create an error messsge. The paper types must match EXACTLY between the print driver and machine. Three things; paper size, paper orientation, paper type (sometimes known as paper weight) must all match between the print driver settings and menu settings on the machine.
It is best to tell us the exact message verbiage, what OS brand/version, 0application used to print, print driver version and type, file type, an electronic size.
Ensure the printer paper tray is set to the size of paper you have loaded, and that the display reflects this, for example Letter (8.5x11.0). Also, set the type to Plain for 20# bond weight paper.
Before you print, check the electronic size of you document. Is it Letter? If not your application must be able to resize and print on Letter, otherwise you will get a paper size/type mismatch error. Most errors like this are because your document size electronically is not Letter (maybe A4, maybe you downloaded a doc from a European web site) and thus can't print because the size differs.
Always check the properties of the doc to see if it matches the paper size and orientation.
In some apps, such as Adobe Reader, you can select an option to shrink or expand the image to fit on the different size paper.
A4 paper is 8.27x11.69 inches, Letter is 8.5x11.0 so not the same.
Again, ensure your print application and/or driver paper size, type, and orientation match the paper loaded in the printer, and ensure the printer settings and display correctly refect this.
이 답변이 도움이 되었나요?
지난 24시간: 5
지난 7일: 6
지난 30일: 25
전체 시간: 11,086
댓글 4개
Hi.
Problem description: I am using a Canon isensys 4350d printer. Whenever anyone tries to print to it, the first page prints and a message comes on the display asking "use current size, Yes/NO". Once I press the button under yes, it reprints the first page and will ask this question again periodically until the document is printed. This occurs regardless of what programme the user is printing from and what computer the printer is hooked up to.
metro_kaushik 의
problem description: i am I am using a Canon isensys 4350d printer. Whenever anyone tries to print & photocopying the paper comes empty & the message of display is like load cassette paper A4 please what can i do help.
thomas key kamuti 의
First, the Canon MF line are re-branded HP machines.
Second, the microswitches could be going bad that are used to automatically detect what size you have loaded in the tray.
Last, check if it is under warranty, these are not built to last.
leafybye 의
Check your settings for paper size abd type.
leafybye 의
