adjusting deck height riding mower
mower has 6 height settings. it is cutting too short. how is deck height adjusted? 16 hp 42" cut 6 speed trans.
좋은 질문입니까?
좋은 질문입니까?
push the button on the long handle on your right and slide forward or back toward you to adjust cutting deck height
이 답변이 도움이 되었나요?
Even using the lever the deck has no height I have the same problem on my kgro
I have the same tractor. There are adjustable rods at the front that adjust height but not too much or the back of the deck is lower.
size oil for kgro power pro 18 hp 42 cut
이 답변이 도움이 되었나요?
kind oil use for kgro power pro 18 hp 42 cut
Adjusting the rods at the front helps but not too much of the back of the deck is too low.
I have to replace the blade drive belt so more head scratching to figure this out.
Pulling the deck off is a pain In the tush.
hope my suggestion helps.
이 답변이 도움이 되었나요?
I have the same tractor, it runs and all but the deck won't turn the blades. Does it need adjustment and how do you do it? Thank you.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 3,668
