주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Pill은 Beats Electronics LLC에서 생산하는 Beats by Dre 제품 라인의 작고 휴대 가능한 Bluetooth 스피커입니다. 직접적인 오디오 및 Bluetooth 연결 기능을 갖추고 있으며, 전화 통화를 위한 내장 마이크도 포함되어 있습니다. 이 기기는 직관적인 구조 덕분에 비교적 수리가 용이합니다.
Beats pill not Charging
My beats pill is not charging. Can it fix?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 24
댓글 3개
My beats pill won't work either I've been pretty rough on it and so when I plug the charger into the speaker I've accidentally pushed the metal part inside the pill and it won't charge
mine is in great condition but when i plug it in nothing happens and after 3 hours of charge it did not turn on
my beatspill has been broken for months and the metal part inside the charging part like moves around and when i put in the cable it just falls out! please help
댓글 달기
답변 7개
가장 유용한 답변
A very prevalent problem in lots of bluetooth speakers, including the Beats Pill. The micro-usb spec doesn't specify a robust enough attachment to the motherboard. Over the course of use, the jack is literally pushed off the PCB, sometimes (often) taking the traces off with it. The replacement of the micro-usb jack is very often not straightforward at all, particularly when the traces have been lifted off. If you have skills, it can be done, but if not........
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I had a guy push the wrong charger In it it bent the pins just need parts looks like easy fix I ha VB e eltronic skills where do I find those parts
댓글 달기
You'll want to troubleshoot the issue to narrow down the failed component.
  • First check your wall outlet, make sure it's providing power
  • Check the charging cable against another, known working, cable to verify that works.
  • Use canned air like Dust-Off to clear out any debris in the charging port itself.
  • Use the guide on our website to open up your device and replace the charging port if necessary.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
MGOM. Bluetooth speaker trun off not properly
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What you need to do is charge it as much as you can than turn it on after that hole the "b" button and the power button hold it the red light from the charging input will turn green and back to red three times
It should work after
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi. I have done that but it won't hold charge at all do you have any other ideas? Thanks
댓글 달기
My beats pill not charging
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Where can I get it fix
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your Beats Pill isn’t charging, try the following steps to troubleshoot and potentially fix the issue:
  1. Check the Charging Cable and Adapter:
    • Ensure the charging cable is properly connected to both the Beats Pill and the power source. Try using a different cable or adapter to see if that solves the problem.
  2. Inspect the Charging Port:
    • Look for any debris or damage in the charging port. Use a soft brush or compressed air to clean it gently if needed.
  3. Reset the Beats Pill:
    • To reset your Beats Pill, press and hold the power button for about 10 seconds until the light flashes. This can sometimes resolve charging issues.
  4. Check the Battery:
    • If the battery is completely drained, it might take a few minutes of charging before the power indicator lights up. Leave it connected for at least 30 minutes.
  5. Update Firmware:
    • Make sure your Beats Pill has the latest firmware. Connect it to a device and check for updates if possible.
  6. Try a Different Power Source:
    • Plug the charger into a different outlet or USB port to rule out issues with the power source.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Phinisia Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 50
전체 시간: 44,893
