주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
Is the stand removable?
Hello,
does anybody know if the stand can be removed? Does this "card trick" still work?
I´m not talking about VESA mounting, I would just like to remove the stand and connect it later again...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
No, the new thin series iMacs use a different design which prevents removal externally.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
BUT they can be removed. One has to completely dismantle the machine and then one has access to the tiny screws that hold it in there. Just be 1) handy and not clumsy, 2) watch several youtube videos re the dismantling 3) use a clean open desk space to do it and 4) use 3M double sided tape when putting the screen back on.
의
@davidperry - Externally was what the person was looking for.as then want to travel with the stand removed and then put it back on. Apple failure was not making it an easy part to remove or exchange for a VESA mount.
Yes, you can replace it after completely disassembly of your system! Thats a bit much for a DIY'er and not something someone would do if they are traveling a lot with the system.
의
댓글 달기
답변을 추가하세요
kepp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 27
전체 시간: 946
