주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년 6월에 출시된 1005HA는 "조개껍데기(Seashell)" 디자인으로 식별되며, 운영 체제, 내부 저장 장치, 배터리 용량에 따라 다양한 모델로 제공됩니다.
Problem with my EEPC
I formatted part of a key USB my hard drive C: with Gparted. so I deleted lartition hidden.
I does not happen again to install Windows XP from a USB key because it tells me that it can not find C: drive on my EEPC.
Thank you for your solutions
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
So you deleted your hidden recovery partition? Then you cannot use the recovery option in the BIOS anymore.
"C:" is not a physical drive, it is the name ("drive letter") of a file system of a partition on a drive. A proper operating system installer should first give you the option on which physical drive to install. Then you may even create a partition of your preferred size. This will get formatted and named "C" as default. Then the installation starts.
I don't know what's on your USB key, but maybe you need to prepare it newly from a proper CD image. You may also connect a disc drive via USB and install from a disc directly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Didier 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 31
전체 시간: 526
