주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 2월에 출시된 1,410만 화소의 사진 및 동영상 촬영 가능 카메라입니다. 현재는 단종되었습니다.
How to Fix no Power
How to Fix no Power...i dont know how to fix this...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
It looks like I have some corrosion in one of the battery chambers of my camera, is there and way of sorting this and repairing??
의 공유
댓글 달기
답변 3개
Check the wires and contact of the batteries. If all are good. Check polarity of batteries. If all is good. A tiny line of the circuit board is burnt because you put the batteries in a wrong way And there is no fuse.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If there is burnt bit in the circuit board and no fuse what can I do to fix this problem?
의 공유
댓글 달기
To fix the burn in the circuit board you have to have a soldering gun, flux paste, tin- lead and good soldering skills. To repair , first you have to find the area that has the open circuit, then remove the green material that protects the cooper for corrosion. Put a bit of flux paste on the expossed part of the circuit that we previously peel. Then solder the area putting a bit of tin-lead. Find a piece of wire (small caliber..18-24 gauge)to make a bridge in the 2 areas.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had a similar problem. The camera would power on, and I would even get a couple of pictures, the it would shut off and could not be turned back on.
Long story short. It turned out that I was using rechargable lithium batteries and the camera was expecting alkaline. I gather there is a different power profile.
I updated the settings and have not had another problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
cilmarbbacus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 17
지난 30일: 34
전체 시간: 2,608
