주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lexus ES 럭셔리 세단의 5세대 모델입니다.
Headlights keep turning off.
My headlight keeps turnong off on its own while I'm driving. How can I tell if its just a bad bulb or the whole head unit has to he replaced (much more expensive!)? How and what part do I need to replace it with?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개:
I have the same issue. The passenger side or the drivers' side just turns off; every time I brake, one of them turns off. Often, while driving, it just turns off on its own.
의
I have 2014 Lexus ES 350 have the same issue the headlight turn off on passenger side and turn off driver side while on driving at night
의
I have a 2007 Lexus es 350 an when I turn my head lights on the driver side goes out right after turning them on . We changed the fuses but it still does it. What can I do about this?
의
댓글 달기
답변 3개
Are you saying one bulb only turns off and is it the same bulb?
Is your car equipped with HID headlamps?
If it is often what happens is the ballist starts to fail.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check connectors, if they're OK, replace bulb
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You should replace the adapter of the headlight.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
greenjacket99 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 4,803
