주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
532 질문 전체 보기
Is it possible to use a SSD instead of my optical drive?
MacBook Pro unibody early 2009
The question is. When I remove the optical drive. Will a SSD 2,5" fits on that place? Can I use a solit state disk on the place from my optical drive.
I want to use an extra SSD for OSX and stay using my harddisk for data. I never use CD's/DVD anymore so, that would be a great solution.
Thanks in advance,
Alex
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 해법
Your MacBook Pro should be one of these two models:
  • MacBook Pro 17-inch 2.66GHz (MB604LL/A) Intel Core 2 Duo
  • MacBook Pro 17-inch 2.93GHz (CTO) Intel Core 2 Duo
What you need is called an Optical Bay SATA Hard Drive Enclosure
http://www.ifixit.com/search?x=0&y=0&tex...
I can't tell if you need the 9.5 mm or the 12.7 mm till you confirm your model. Even if I can't, iFixit parts will know. Just ask them here:http://www.ifixit.com/Info/contact
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Hi Mayer, my model is a begin 2009 MacbookPro 15" I will ask it to ifixit as you told me. Good to know that this is possible! Thanks for help!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have swap my optical drive with a SSD using the enclosure adapter on my Macbook Pro. Now this new SSd sometimes disappears. I have to reboot my macbook pro, and sometimes that also does not work the first time. Any clues ? thanks !!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Oh yes, my model is Macbook Pro 5,2
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alexander van der Linden 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,900
