주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honda Element는 수정된 CR-V 플랫폼을 기반으로 제작된 소형 크로스오버 SUV로, 오하이오주 이스트 리버티에서 생산되었으며 전륜 구동 및 사륜 구동 모델로 제공되었습니다.
How repair engine coils
my car is stalling out Could the 4 engine coils be the problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Is your Check Engine Light on? Have you tried to get it scanned for any error codes? Unlikely that all your coils failed at the same time.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
Possible, you should get a cheap OBD 2 scan tool to check for mis-fire DTCs in the system. But the easy way to check for misfire codes is to look at the mil light when the car is running. misfire will make the mil light flash.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
By any chance do you drive a standard? Elements, especially those that are sticks, tend to suffer from the exhaust valves going out of spec much sooner than normal. In my experience (the three times this has happened within 130K) is that I would drive semi-aggressively from a cold start. When I came to a stop in the first 5 minutes of driving, the RPM gauge would drop too low and stall. Turning the car back on would keep me moving again for usually the rest of the drive.
You can literally say to the mechanic, "my exhaust valves are out of spec" and they can fix it from there. It's cost me between 150-300 depending on the mechanic doing the work.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
peder Larsen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 737
