주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto G (2세대)는 Moto G2라고도 불리며, 2014년에 출시된 Moto G의 후속 모델입니다. Moto G2는 5인치 720p 디스플레이와 Qualcomm Snapdragon 400 프로세서를 탑재했습니다. 모델 번호는 XT1045, XT1040, XT1039, XT1069, XT1068 및 XT1064입니다.
Bottom Speakers not working.
In the recently hit earthquake in our country Nepal, my Moto G 20014 (XT1064) fell of my shelf but no damage was seen in the screen. However, later I noticed reduced speaker sound, specifically the bottom one. Then I found that the speaker was not working at all. However, if I gently hit the backside of the phone where the bottom speakers are located, it gave me output for a while and then again stopped working. I tried a couple of times and it worked most of the times. So i think the connection of the speaker has loosen and i was hoping if your team could help me fix/repair the loose cable connection.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
Hi,
You need to remove the back cover and then remove the first covering of the phone.
After that you can try removing the speaker located at bottom right.
Speakers are rectangle shaped and black in color.
Clean them and check if contact pins are misplaced.
after that place them correctly and attach the covering.
Check if it works.
Please note that you dont need to dissemble your phone, just open the second covering with screw driver and you can see the speakers or use any iron and look for magnet at bottom.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a similar problem. I replaced the battery. Now, my speakers don't work. At first, it was the bottom so. Now the top one doesn't work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ssanjysh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 5,645
