주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 12월에 출시된 삼성전자의 아시아 시장용 안드로이드 스마트폰이며, 다양한 모델 번호로 알려져 있습니다. 모델명 SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W을 포함합니다.
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 21
댓글 28개
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
That was a fantastic clue. works perfect!. Thank You Dude.
Wow that really helped me thank you very much
worked perfectly. thanks much!!!
Amazing advice! Nothing else worked but this did. Thank you :)
댓글 23개 더보기
댓글 달기
답변 4개
선택된 해법
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
이 답변이 도움이 되었나요?
점수 33
댓글 21개:
Dat was really helpful. ..thanks!
its working thank you so much
its good idea..... thank u .....
good job...... i really like u......
it's work... thanks
댓글 16개 더보기
댓글 달기
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
Many, many thanks
댓글 달기
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
댓글 달기
답변을 추가하세요
Billy495 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 60,601
