주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 M8407 / 550 또는 667 MHz G4 프로세서
More RAM chip upgrade
Hi. There are 2 RAM chips/cards in my powerbook. I would like to speed things up. What can I change ? One chip says 256MB. The other is Smart SM564328578NW3R. Thanks.
Update
So if I install 2 new chips do I have to run OS9 and firmware to get things going ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
You shouldn't have to do anything after adding the new RAM. Either 9 or 10 will see it just fine.
의 공유
댓글 달기
답변 3개
선택된 해법
You currently have two 256 modules. You do not have to upgrade in pairs so you can remove one and add a 512 MB 3.3V 144 Pin SDRAM SODIMM (PC133) for 768 MB or replace both for 1 GB RAM. Here's the chip you need: http://www.ramdirect.com/vcom/product_in...
Here's a 5400 RPM ATA hard drive that will also give you a boost: http://www.ifixit.com/Apple-Parts/160-GB...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
의 공유
댓글 달기
가장 유용한 답변
iFixit stocks all the RAM upgrades for your machine as well.
http://www.ifixit.com/Apple-Parts/PC133-...
As long as iFixit is providing all these resources (funded by parts and tool sales), it's nice to support them by linking to iFixit products when available, instead of off-site.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
You're correct. My bad. Hopefully they'll soon provide a quality RAM search engine and I'll look to them first. Old habits die slowly and I looked first to where I knew the answer would be and without thinking that iFixit might even carry that RAM I put in a link to someone else. My apologies.
의 공유
댓글 달기
The Max RAM for this machine is 1GB, so you can upgrade the RAM, and a faster HDD, thats about all you can do on the hardware side. and im not sure if there are faster than 4200 rpm Pata drives for this machine.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
의 공유
댓글 달기
답변을 추가하세요
Rick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 2,114
