주요 콘텐츠로 건너뛰기
The B15 from Caterpillar is an Android based smartphone featuring a rugged, durable design and a fairly long battery life. Released in early-mid 2013, the B15 features a 4” LCD display, 2000 mAH Li-Ion battery, and ships with Android 4.1.
Why no charging the my bathery
why its no charging the my bathery
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
nagylevente20, there are a few possibilities. Check to make sure that your cable and charger are working. Next check your charging port, look for any loose or broken pins. After that replace the battery. Then re-evaluate. If it is still not working, you could have some issues with the charging circuit on your logic board. Start with the easy stuff first. Here is the guide for your battery.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
nagylevente20 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 704
