주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 3 Slim은 원래 모델 번호 CECH-2000을 가진 PS3 게임기 버전입니다. Sony Computer Entertainment에서 제작했으며 오리지널(뚱뚱한) PlayStation 3의 많은 문제를 해결했습니다. 2009년 9월 1일에 출시되었습니다.
I'm having problems with error code 8002F1F0
I tried updating my system, and it failed multiple times before giving me this error code. (8002F1F0) I can't even get into safe mode. Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 5개
가장 유용한 답변
Hey Cameron, I have two options you can try (try both):
Option 1
Try to download the update from Sony's website and put it on a flash drive and install via USB.
Option 2
As the update will start pull out the HDD (litte plastic cover on bottom of the PS3 and one screw). Then it should run to 99% and stop without any messages. Then, unplug the power to restart the system. At the next restart it will run to about 45% and then jump to 100%.
-Let me know how it goes.
-Please accept this as the answer if it answers your question.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Do i put the hard drive back in when i unplug it
의 공유
OMG dude I just Get my rpoblem SOlved (srry about my english), My console always give me error at 66% i restart it al most 20 times Them when it was close to 66% i push the power button and the sistem get fix .. i can't belieave it jajaja
의 공유
Hi, my ps3 has now reached 99% (finally!). Based on your suggestion above, do I unplug the system and plug it back in with the HDD back in the system or not for it to jump from 45% to 100% on the next restart?
의 공유
Does not work tried it get the error every single time 8002F1F0 at around 42% everytime tried this and same thing happens
의 공유
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
At The Next Do We Have Put HDD inside again, because I have tried inserting but still update get stuck at 99%. Please request for help !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Stuck here too... get to 99%, unplugged and tried restarting without HD but it wont start download due to missing component.. if i reinsert it gets stuck in same 66%, tried both ways, and already switched out the lithium battery in the MB but still no luck. I really think its the whole BT issue since i know my controllers stopped working without being connected directly via usb. Please help someone???
이 답변이 도움이 되었나요?
점수 0
댓글 달기
We need help with a code for playstation 3
8002F1F0
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cameron Williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 58
전체 시간: 9,093
