water poured on my lenovo ideatab s6000 it not working
water pored on my tab and its not working pls help me
좋은 질문 입니까?
좋은 질문 입니까?
bisola, you want to treat this just like any other device. At this time my advice to you would be to no longer try to start,charge, or sync your tablet. Totally disassemble your tablet and remove the battery. Use this guideto do so.Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Use this guidefor the cleaning. It was written for a 3G but all the points still apply to your tablet as well. Check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Right now, everything will only be a guess, and the longer you wait the more corroded it will get. Hope this helps, good luck."
안내서
난이도:
어려움
1 - 2 hours
안내서
난이도:
운영
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 94
