주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMac은 교육 시장을 겨냥해 2002년 4월에 출시된 G4 기반의 올인원 Mac입니다. CRT 디스플레이를 탑재한 마지막 Mac이며, 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
Am I using the wrong ethernet cable?
when using an average ethernet cable,emac
won't recognize it.
Will the Belkin RJ45 FastCAT™ 5e Patch Cable, Snagless Molded Cable fix my problem?
Also, is there a way to upgrade the 1.1 usb ports with 2.0 usb?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
First thing you should do is just try any other ethernet cable, to rule out a bad cable. Ether cables are fairly delicate and shouldn't be bent too sharply. Are you seeing "No cable connected" in the Network control panel? If you still get this message with a different, known-good cable, then your Ether port might be toast, but first you should try zapping the PRAM, resetting the NVRAM, and booting to a different system, to rule out software.
If your port appears to have died (I've had this happen a few times) you can get a USB-Ethernet adapter like this one: http://eshop.macsales.com/item/Macally/A...
Of course, first check ifixit to see if they have something like it!
Zap PRAM: reboot while holding down command, option, P, R. Keep holding down till you hear 3 chimes.
Reset NVRAM: hold down command, option, the letter O, and F. You'll get a while screen with black text. Type "reset-nvram" and Return. Type "reset-all" at which point the computer will reboot automatically.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
NO and
NO
Re the cable, what are you connecting to, you may need a crossover cable?
이 답변이 도움이 되었나요?
점수 -1
댓글 5개:
Macs since a long time back don't need crossover cables; they can sense what's needed and deal with it internally.
의
A cross-over cable would be used to connect like devices (eg. 2 hosts, a desktop to a laptop). Straight-through cables are used to connect different devices, such as a host to a router.
You may want to check up on your answers before posting.
의
Many recent Macs, including all Intel Macs, do not require crossover cables. See http://support.apple.com/kb/HT2274. As for this eMac, if it's ATI graphics or later, it does not require a crossover cable; they have Auto-MDIX, which automatically configures the ethernet connection. The OP does not say what they are trying to connect to, as you correctly point out, but one can presume it's a hub, switch, or router, as that's the most common scenario.
의
Still, the probably scenario (unlike devices), a straight through, the most common type of ethernet cable, is the needed one.
의
AKA a patch cable.
의
댓글 달기
답변을 추가하세요
Celeste 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 25
전체 시간: 2,945
