주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S4 Active는 견고한 Galaxy S4 버전입니다. 현재 AT&T의 4G LTE 네트워크에서만 사용되고 있습니다.
Back button not working
The back button on my s4 active does not work, but the other two do. I have replaced the old button assembly with a new one and it is still doing the same thing. Would this mean there is a problem with the daughterboard? The phone charges fine as well. I have also tried a hard reset and wiping the cache partition but they still didn't fix the issues. Thanks for any help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Hey,
I love this phone, I've had mine for years now, those soft keys on the front of the phone are actually controlled by the charge port. If you plan on replacing it yourself there are a few things to keep in mind.
Order more than 3. Yes, the failure rate on these parts is SO BAD that ordering less would only leave you frustrated. The charge port module on this phone controls the three softkeys, the charge port..(obviously) the antenna, and the main mic.
ALSO- take care removing the coaxial cable that runs down the right side of the device (when the phone is on it's face) if it gets damaged in the least, you will have abysmal signal, and you might be able to make a phone call standing on top of a cell tower... MIGHT.
Your problem is an easy one though! Don't worry, and don't go about doing anything software related, as 9/10 this probably isn't your issue.
-Samantha Stout.
Device Saver since 2013, fixer since 2002.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
jparks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 38
전체 시간: 3,635
