주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia Lumia 630/635는 2014년 6월에 출시되었습니다. 모델 번호 635로 식별됩니다.
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
댓글 달기
lumia 635 power baton bord not warking
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
gobstopper2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 25
전체 시간: 1,340
