주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Parrot의 장난감 쿼드콥터 2세대 모델로, 스마트폰을 통해 와이파이(Wi-Fi)로 제어하며 HD 카메라가 장착되어 있습니다.
My drone does not take off.
my drone does not take off after replacing the central cross section. I think the blades are spinning the wrong direction.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
I found elsewhere that I should use the reset button on the bottom of drone, however my reset button doesn't seem to be working and I think this may have been damaged during crash. would like other suggestions or a how to on replacing the reset button. Do I need a whole new board or can the reset button be replaced independantly?
댓글 달기
답변 2개
가장 유용한 답변
Is there any software for this for pc? As my blade qx3 has, and you can fire up each motor separately and shows on the screen which way they should rotate.
Top left and bottom right rotors should rotate the same. And top right bottom left should rotate the same to each other, but opposite to the other pair.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
My drone is going to one side
Mine is doing the same
댓글 달기
Yes, have you changed the blades? If so, make sure the blades are on correctly. What I mean is that a blades at on the a motor, while c, for counterclockwise blades are on the c motor. Search up propeller replacement on Google
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
robredanz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 9
전체 시간: 2,666
