주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
질문 마감됨
Magsafe LED going ON/OFF and the battery icon changer on/off
Hello friends I again,
I got a MacBook Pro 13 " early 2011 with the following problem. The magsafe is plugging and unplugging (led go ON/OFF), and the battery icon changes accordingly, and as if it were placed and taken out of its connector.
I tested three different magsafe and all the problem repeats itself, most work well in other Mac.
My doubt is, would issue the logic board Magsafe (internal) or own mac motherboard?
Is there a way to isolate the problem, because despite other available Mac'm afraid to dismantle the good and then appear any problems in assembling already reset the PRAM and SMC the problem continues, the difference is that there are times that seems to begin to measure the Mac heats.
All help is welcome, and apologize for my poor English.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Your MagSafe DC-In board contacts are damaged. The fact your screen Icon alters from the battery to AC cord implies that. The middle pin is the signal link between charger & your system. Also make sure the AC power adapter cord is not damaged if it is get a new power adapter as you could short out the signal pin damaging the logic board.
Here's the IFIXIT guide to replace it: MacBook Pro 13" Unibody Early 2011 MagSafe DC-In Board Replacement.
To see the systems thermal sensors download this app: Temperature Gauge Pro. Paste a screenshot when the think the system is running too hot for us to see. Go into edit mode within your question to post the pictures.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 116
