주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia J는 안드로이드 소프트웨어로 구동되는 스마트폰입니다.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
Do you mean this connector?
이미지
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The problem that you state.have different problem with mine situation
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
filerzr 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 27
전체 시간: 3,194
