주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 Nintendo DS Lite는 2006년에 Nintendo DS의 후속작으로 출시되었습니다. 이 기기의 내부에 진입하는 방법은 간단하여 손쉽게 수리할 수 있습니다.
How fix bent something inside card reader?
I watched inside card reader.
then I saw bent something.(just one)
Is that not right?
Everything staight up to bottom
but just one is left to right.
Do I have to replace or remove it?
Thank you!
I'm waiting for answer :-)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
선택된 해법
if you know how to solder. you can replace it with this..
http://www.dealextreme.com/details.dx/sk...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you. It will help for me.
의 공유
ok, i have to accept that you changed your mind and accepted his answer.....
의 공유
댓글 달기
가장 유용한 답변
ok, i was right.
it was not necessary to open a new question for that. but you can close the othere one by accepting the answer there.
the card readers are very weak - surely you could try to bend the wire back - but it will most likely break.
replacing the card reader is the only real fix for that
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Yes, you're right! :-)
I'm gonna replacing the card reader.
Thank you for answer.
의 공유
댓글 달기
I have a scan disk card as it was inserted into a card reader it was bent right in the middle. Can the data be recovered from it...it has several pictures and video on it?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Stephanie, you will get much better help if you ask your own question and not tag it on as an answer to an old question. When you ask your question you should also give more info. Like the type of the card and where is it bend etc. Good luck
의 공유
댓글 달기
I watched inside card reader.EverytDo I have to replace or remove it?hing staight up to bottomThank you I'm waiting for answer
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Taeyeon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 6,115
