주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z는 2013년에 출시된 안드로이드 기반 스마트폰입니다. 5인치 풀 HD 디스플레이를 탑재한 Xperia 제품군 중 가장 큰 스마트폰 중 하나입니다. 모델 번호는 C6603/C6602 등이 있습니다.
Adhesive will not stick
I just fixed a Sony Xperia Z and after a little while the adhesive does not want to hold the screen in some places. Do i need to buy a better adhesive?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I have used kitchen silicone. I have changed this phone display 3 times works every time :)
댓글 달기
답변 2개
가장 유용한 답변
This seems to be a big issue with S5's and Sony Experia's. Best thing to do is to make sure you thoroughly clean frame, apply a plastic adhesive activator and use high quality adhesive's. Also you need to check your frame/chassis for damage, separation, and or whether or not its bent. We've been looking for a supplier for Sony Experia OEM water proof adhesive. If anyone knows where to get it can you please let us know. Thanks
이 답변이 도움이 되었나요?
점수 1
댓글 달기
heat it up with a hair dryer carefully, then put it on its back facing down, put a little weight on the top and leave to set. as mentioned above make sure the bezel is clean from the old adhesive, there is a glue that does help called B7000 we sell this on our site and its a great glue for this type of job, not corrosive like superglue and its flexible at the same time.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Glue B7000 where can i find it, i can't find it on his site
댓글 달기
답변을 추가하세요
heljar97 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 876
